Hello dear friends,
I’m building an entertainment center composed of three cabinets. I was so eager to finish it with hand rubbed shellac. So I tryied it on a piece of scrap and was delighted. I finished the two smaller pieces of the whole entertainment set only to find out the the end result sitting in my living room turned out to be too orange in its color. Intrested in seeing what is the natrul color of the wood (cherry venner and solid) with an oil finish I tried that too on a piece of scrap to find out that that is the color, look and feel that I want.
So I took the original shellaced scrap and tried sanding of the shellac in order to finish it with oil. To my amazment it worked with out burning through the venner.
Two questions: 1. Am I in for any more suprises if I try to sand off the two finished parts of my set to finish them with oil. 2. Should I mix the oil (Teak oil) with varnish and/or anything else for more toughness and durability (although its just electronics going to seat on the pieces).
Thanks in advance for any suggestions.
Rez, shellac is the easiest finish to remove -- put away your sander and get some denatured alcohol at the hardware store. No chance of a "whoopsie" with that technique.
In regards to finishing with oil I am still looking for the oil+varnish furmula. (Teak oil). I would love a small explanation about the benefit of such a formula as opposed to using only the oil. Looking forward.
Rezberg,
My suggestion would be to back up a bit and get a better understanding of what your asking...so you can hear the solutions being offered. I'm a relative newbie also, and I have found myself confused by recommendations because I did not understand the context. Remember, building or making the piece is only 50% of the job...
It helps me to understand there are four parts (or Stages)to the finishing process; staining, sealing, finishing and polishing. There are also numerous combinations of processes to acheive the results you seek....but you can't necessarily plop in a new element into the process without changing other elements in the process.
So as FG said, you can strip the shellac, put on blond shellac, or put on oil first and then blond shellac....or switch to Watco and build an oil finish....or lots of other options....varnish, lacquer, etc.
Edited 5/23/2004 8:17 am ET by BG
Another factor in getting the finish you want is lighting. I work in my garage shop which has flourescent lighting and/or lots of sunlight if the door is up. When I make samples, I have to take them inside to see what they'll really look like.
It's also a good idea to make fairly large samples. Using small cutoffs can fake you out.
Teak oil, tung oil finish and Danish oil are all basicly oil/varnish mixtures. They are mixtures of varnish, boiled linseed oil and mineral spirits. Most contain no real tung oil inspite of their name. The exact mixtures are proprietary but 1/3, 1/3, and 1/3 will get you real close. Some manufacturers add a dollop of drier to speed up the drying. This same mixture is frequently also called "Danish Oil" because it gives a finish that resembles the finish used on much of the "danish style" teak furniture imported in the 50's and 60's. "Teak Oils" may contain a little wax and UV inhibitors to make it more long lasting in a marine environment. All oil/varnish mixtures closely mimics a true oil finish but the addition of the varnish resins gives it more durability and protection.
Here are some oil/varnish mixtures:(*)
Deft Danish Oil
General Finishes' Sealacell
Behlen Danish Oil
Maloof Finish
Behr Scandinavian Tung Oil Finish
Minwax Tung Oil Finish
Minwax Antique Oil Finish
Velvit Oil
Watco Danish Oil
McCloskey Tung Oil Finish (contains pure tung oil, not linseed oil)
(*) Courtesy Bob Flexner and some personal information.
True oils like pure tung oil and boiled linseed oil make poor finishes. They do not inhibit water or water vapor, provide no scuff or abrasion resistance and require frequent reapplication to maintain their appearence. True oils are best relegated to coloring the wood. By adding a resin (vanish) to the oil, some amount of protective qualities are imparted. But, the finish still looks like an "oil" finish.
Howie.........
