I’m working on a project in wenge and was hoping for some tips on finishing it. I understand I’m supposed to fill the pores first. Any tips on what product to use and how to apply it? As well, any suggestions on the finish I should use. I just want to bring out the natural beauty of the wood.
J,
I would not say that you are supposed to fill the pores-of Wenge or any other wood, although a few woods can benefit from doing this.
If you want a smooth surface, which is not natural to Wenge, then you have to fill it.
I have only finished Wenge by applying a dark solvent stain and then spraying catalysed lacquer . I have also used a light shellac wash and then wax-also came out nicely.
As an aside- if you have small pieces as in knife handles it looks well if you wire brush it with a power brush along the grain and then finish it. The brush removes the softer parts and accentuates the features.
I've finished wenge without filling the pores, just using a very matte acrylic lacquer. I like wenge a lot, but you need to be careful not to let it look like the cheap laminates of the 1950's which were made using photographs of wenge. In short - don't fill the pores and don't go anywhere near glossy.
David Ring
