Help;
My friend is installing a maple kitchen and maple stairs. He wants to stain the maple. Can anyone direct me to some written information for him that describes a correct method of staining maple so the maple does not blotch? If I could find a step by step procedure for him, that would be very helpful.
Haliaka ( Bob )
Edited 9/9/2008 11:12 pm ET by haliaka
Edited 9/9/2008 11:13 pm ET by haliaka
Cherry-related, but potentially helpful:
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=31063
Thanks for the info Ralph. I do see this article in the Finewoodworking magazine but wanted to find a article for maple only. Still looking.
Thanks Ralph
Bob
[email protected]
You might look into gel stains, General Finish makes a great one.
Can you recommend any written info about staining maple that I can give to my friend who will be staining his maple cabinets and stairs.
Bob
I second the advice about using dyes over stain for maple. Avoiding blotching is tough, though. The dye should allow him to sand out what blotchiness your friend doesn't like and the rest he can just call curl.Norman
Thanks Norm;
Do you know of any article or book that would have this advise?
Bob
I recommend Understanding Wood Finishing by Bob Flexner as being an excellent source of finishing informations, including the why's not just the how's.
Frankly, I don't see why you are unwilling to accept the concepts explained for cherry to be applied to maple. They are both diffuse porous woods, with rather similar structure. Both tend toward blotching in similar ways. If the methods work with cherry there isn't any reason to suspect that they won't work with maple.
Besides, you will not be risking much, since you should NEVER apply a finish to the wood on an actual project, without making a full test of the entire finish schedule from the same wood.
I accept and know that maple and cherry have the same qualities when staining. But when recommending a procedure to a friend who has no woodworking or staining experience, If something should go wrong or not look the way he wants it, I dont want to be the one in "hot water" because I recommended a Cherry procedure on a Maple Kitchen.
You are going to sit on him until he agrees that test boards are going to be made, right. That pretty much limits the degree of hot water.
Understood!!
Bob
Bob, Steve Schoene knows a heck of a lot more about finishing than I do. I'm a novice, but I second his recommendation: Understanding Wood Finishing is my bible on the subject.I recently finished a maple vanity, and I drove my wife nuts with all the samples I showed her before deciding on a final approach. (I knew I was done when she couldn't tell the difference between two samples, but I still could: there lies madness.) I think I showed her close to 20 samples, all from the same boards I used for the vanity. I wrote the formula on the back of each one, so I can refer to them in the future as well.There's no "right"way; the best method is the one that produces the look you're after, even if the next guy thinks it's ugly.
Thanks for the info.
Bob
IF your wife liked it. I would leave it a that and ask her for a big hug!
Maple is a close-grained wood and it does not accept pigmented stains very well. I think you will have better luck with one of the water-based dyes. Check the Woodcraft or Lee Valley catalogs and you'll find what you're looking for.
Jim
Send it to a PRO with spray equipment!
