Gary,
Thanks for all of your great articles in FWW. I always find them informative and inspirational.
I will soon be making a small set of hanging shelves out of cherry to go into a friends bathroom. It will have one small drawer at the bottom.
I have it in my head that you should not finish the inside of drawers. Is that a good general rule? And if so, I’m worried about the constant moisture change in a bathroom (warping and sticking, etc). Any advice?
While I’m asking,,, normally I like to finish with Shellac. But I’m afraid I’ll have to go to some kind of poly in this environment. Do you agree? recommendations?
Thanks in advance,
– david wolfe
David,
Thanks for the kind words.
I always finish my drawers inside and out. I also use shellac for the insides so there's no lingering smell inside them. I see no problem using shellac in this environment unless you foresee lots of splashing around. But I would finish inside and out. You can also use shellac on the inside and what you like on the outside for more protection. Good luck. Gary
