I have a recently completed project in cherry. I had some very nice cherry that was used for most of the cabinet, however, I did not have enough and had to go to another source to get more cherry. The second batch, it lighter in color, a bit more pink-ish, than the other which has darker, red-ish browns. Although I believe age/exposure to sunlight without finish is part of the difference, after a couple of weeks in front of a window in sunlight, it is clear they are not going to match.
So, the question is, based on the finishing technique I am planning, do the experts think the pieces will blend well enough? The finishing process I have chosen is outlined by Glenn Huey and includes the following basic steps: 1) flood with dye, 2) wash-coat of shellac, 3) van-dyke brown glaze, 4) another wash-coat of shellac and then 5) top coats of dull-rubbed lacquer.
My thinking is that the combination of dye and glaze will blend the pieces well-enough to make it work. I would test the theory but none of the older cherry is available to test. Are there other thoughts?
Thanks in advance for any assistance you are able to provide.
A couple of weeks is far too little time to tell what they will eventually do. My experience with BLO and shellac on cherry is that it the cherry continues to darken for years.
I'm not saying yours will ever match, just that it may not be possible to know yet.
