I have 2 questions regarding black walnut which I have never worked on before. First, what is your preferred finish for a lightly used cabinet top? I would like it to really stand out.
Second, what would be a complimentary wood to use for this low entertainment cabinet? I need a traditional -not modern- style to keep my wife at bay. Thanks!
David,
Personally I like to use a basic nitro lacquer for cabinets such as this. If you don't spray your finishes you may consider something like Deft brushing lacquer. It's a basic lacquer that has retardants to make it flow out. It still dries very quickly so be aware.
Another option is shellac. You can use one of the darker types like garnet which will add a little color on it's own, or simply use SealCoat which is a de-waxed blonde type which will have virtually no color. It too dries very quickly.
Another option is to use a simple wiping varnish like Minwax Antique Oil. This will produce a very "close to the grain" or in the wood finish as opposed to a film type.
Another option is Waterlox Original. As with the antique oil it is about as easy as it gets. The waterlox will have more body than the Minwax.
Just out of curiosity, why use a complementary wood? Black walnut is pretty nice on it's own.
Peter
Thanks for your reply. I have a stash of black walnut which has air dried for about 2 years. I dont know yet if there is enough for this project because I havent milled it yet - I know I will lose a fair amount of wood. I just wanted to be prepared. Of course I can buy more, but I wanted to know if anyone has had attractive results with another wood. Sometimes I have seen mixed wood projects look somewhat "non-cohesive".
I did a project with walnut and maple. The contrast was quite spectacular.Doug
The Wood Loon
Acton, MA
