I’m building a couple of outdoor benches of port orford cedar. My understanding is that it doesn’t really require finshising if I’m okay with it weathering. The thing is, I’m not sure what this material looks like when it weathers. Has anyone had experience with using this particular wood in outdoor furniture and what would your recommendations be as to finishing or not?
Curious in Oregon
Fine Woodworking Recommended Products
Shop Fox W1826
The thick, felted bag on this Shop Fox is a plus and a minus. On one hand, it makes the unit much less expensive than collectors with canister filters, and also lighter and easier to hang on the wall. Without a separate plastic bag to catch chips, however, they stay in the felt bag, and the shortish zipper on the bottom makes it tough to shake them out. Otherwise, the W1826 is an excellent value.
Chicago Electric Belt Sander
Weight: 7 lb. Amps: 6 Variable speed: Yes Belt alignment: Good Material removal rate: Fair Sanding flatness: Very good Shaping/scribing: Good Handling on side: Very good Dust collection with hose: N/A
Estwing Dead-Blow Mallet
A quality dead-blow mallet that packs and punch but isn't too heavy for furniture work.
Festool TXS 18
2 x BP 18 Li 4,0 HPC-ASI battery pack; rapid charger TCL 6; CENTROTEC BH 60 CE Imp magnetic bit holder; CENTROTEC Chuck; AN-XS right-angle adapter; FastFix keyless chuck 3/8“ (10 mm); BKS SYS3 D5 PZ TX 100 CE bit cassette; bit PH 2; Belt clip; Systainer SYS3 DF M 187
CrushGrind Pepper Mill Mechanism
Matt Monaco designs his pepper mills to accept the CrushGrind mill mechanism, which he likes because it doesn’t require drilling through the top of the mill’s cap and having hardware exposed on top.
Yeah, orford cedar has natural weathering feature. It will turn silver greyish in color if you let it stay as is.
