I was working on a finish for a table, and I was looking for more of a stain finish. I used a wipe on poly that was satin (i know how you treat this has more to do with the finish than the type of finish you use). However after I put on the last coat and let it sit for about a week, I nocked it down with some 600 grit sand paper and then some 0000 steal wool. And then rubbed it down with some furniture polish.
I didn’t really expect the finish to come out so shinny. I left it because it looked really nice, just not the results that i would have expected.
So my main question is next time how to i get the nice satin Finnish i was going for?
"So my main question is next time how to i get the nice satin Finnish i was going for?"
You can take pretty much any relatively smooth finish, whether it is flat, satin, eggshell or whatever, and polish it to a gloss finish. Sounds like that's what you did. If you want to de-gloss it, try some pumice or rottenstone on a damp cloth.
Mike Hennessy
Pittsburgh, PA
So basically just mess up my nice glossy finish:) Thats what I figured, after you have dulled it do you just leave it as is? I guess if I then used a furniture polish to sort of seal it ( i am pretty sure i don't need to worry about this but i have some weird issues that make me think i need to seal it somehow). I know not to "dull" it so much that i go through the finish so this shouldnt be an issue.
Well, I usually use Butcher's wax as a final step. I like the luster and the feel it provides. I avoid furniture polish 'cause I've never found any that wasn't actually bad for the furniture.
Mike HennessyPittsburgh, PA
Butcher wax, That would work. It would give me the sense of finishing that i need, not necessarily that the wood needs.
I have issues.
As someone over in Breaktime quips:
"I have CDO -- That's like OCD, but the letters are in the proper order." ;-)
Also good to know:
I usually finish with several coats of gloss, then only use the satin on the last coat or two. Keeps the finish from getting murky as it gets thicker -- makes for better "depth".
You may be able to simply apply another coat of satin, depending on what was in your furniture "polish".
Wax is about 95% just for appearance--it's principal function is to make things shiny, but that's not what you wanted. The varnish seals--it is all the seal that is needed.
When you rub with pumice and/or steel wool, or rubbing compound you leave the surface just rough enough to get a less glossy finish. Rottenstone, which was mentioned in one post, will take the finish to quite glossy, as would polishing compound. Sometimes wax is used as a lubricant with steel wool rubbing, but that's to moderate the scratchiness of the steel wool. Anyway, you would remove that wax with naphtha since if you used real steel wool it would just be trapping steel shreds.
I agree with Mikehennessey and Steve Schoene-get the wax off with naptha and apply a final coat of semi-gloss or satin over your gloss. I would try to apply an equal amount of gloss as you put on your piece to scraps to see if you want semi-gloss or satin.
I hope this makes sense.
Pete
wiskytango,
Skip the wax?
With all the protection it's really not necessary. I just work the grit from 1000 down to get the dullness I want.
As stated in earlier reply, even a satin finish can be polished to a "shine".
But I have experienced gloss/clarity issues with "satin" finishes that I later traced back to not properly mixing up the finish before applying. I learned the "flateners" that are added to gloss finishes (to make them semi-gloss or satin finishes) can settle out. Making the top of a can of finish "gloss" and the bottom "satin". Gave me "two-toned" finish as I applied to a table top.
As mentioned, the semi-gloss/satin part of the finish is provided by the "rocks" they put in the bottom of the can. Unless the "rocks" are mixed into suspension, you get a glossy finish.
Personally, I prefer a final rub with Rottenstone and oil over pumice. Pumice seems too coarse to me. Using water with the Rottenstone gives a slightly different effect.
