Does anyone out there have any experience with the Festool 1400 rounter? Is the Festool router as dust free as the their plunge saw?
I went out to my garage shop at lunch today to cut and dado some panels for my fireplace project. To cut the panels down to size I used my FT plunge saw attached to my Fein vacuum, their was virtually no dust as usual. Next, I decided to use the router to cut the dados instead of the table saw. There was a ton of fine sawdust spewing everywhere and I have no dust collection on my PC690. Can sawdust be collected from a router the same way as the plunge saw or is it more like the jigsaw which can’t really be cleared?
I have a 1400 Festool router with one of the Festool "Extractors". (I hate that term, but love the tool!)
I have been plunge routing though 1 3/4" material and there is NO DUST until the final breakthrough - and then very little. There is a clear plastic device that fits around the bit shank; the vac hose connects to this. It is really slick.
For edge routing profiles there is a cup-like device that fits to the router bottom plate. Depending on the bit, you might not be able to use the top gizmo. In that case, dust collection is not so good.
Otherwise the router is great. I really like the one-wrench, ratcheting bit changing. Just press on a toggle and you can ratchet the nut on or off. Hope this helps.
Frosty
The thing about festool is they think dust collection first when they design. I don't have that router but am considering it. I have the domino and ct33e dust extractor. No dust. I'll give you a link to the FOG where you will get more feedback than you can shake a stick at. BTW, prices go up 4/1!
http://www.festoolownersgroup.com/
I got a 1400 just the other day and I tell ya, you won't be disappointed if you decide to get it. The dust collection works really well. It also comes with a chip catcher for when your edge profiling and can't use the dust extractor. They've pretty much thought of everything when it comes to this tool. Definitely the Porche of routers!!! Cheers jointerman.
Russ.
Thanks to everyone for their insights on the FT 1400 router. It sounds as if it really does do a good job collecting dust. I haven't been disappointed with either of my other FTs, but its amazing what I try to justify another FT tool. Those FT Systainers are addictive!
It definitely works as advertised in the dust collection department. IMHO opinion the only weak feature is the depth stop setup. My old DW621 is much better on that feature. Other than that, the Festool is great.
If you build it he will come.
Love it. Dust collection will depend a little on what you're doing, most smaller profiles and dados you darn near eliminate it completly.
I wrote a way too long review on that router a bit ago on the festool junkie site but the nutshell of my 2 cents was man, what a router.
Real trucks dont have sparkplugs
Hi All,
I've got the 1400 and the 1010, both amazing routers. By far the most precise best designed routers available. Matched to the guide rail system you can do most anything.NOTE: Buy the centering cone for making sure the guide bushings are concentric with the collet before using the routers or any routers along a straight edge on on a dove tail jig.I use the 1010 on the Akeda jig and it is truly 100% dust free...ZERO dust.
