I have a Question. We have two 70′ (feet) Spruce trees that came down in a storm.
Are they good for / worth anything besides a shredder?
Much of the framing material in the Northeast is made from Spruce.
With softwood lumber prices down as low as they are these days, you could buy severalfold the lumber you'd get out of those at the cost of hiring a sawyer.
If you have clear lower logs, buck them to 10' and using wedges and hammer split them into balks than can be machined into 2X8's. Debark and airdry them, and when seasoned you can trade them off to boatbuilders as oar blanks.
grandmarnier,
If they are Sitka spruce they are desirable for aircraft, and certain musical instruments..
If they broke off above the ground, they are probably toast. If the ground failed, and they up-rooted, they may be fine. You should look for a small-time sawyer near you.
You can start by looking at this list, it is organized by state.
http://www.woodweb.com/Resources/RSSDGsawyers.html
