I need help locating what appears to be a special door pull. It’s contemporary Euro in style for laminate type cabinet doors.
It’s best described as a black plastic grommet that is capped. To install it, you just route a blind hole in the door about 5/8 deep X 2.4 diameter. Insert the bottom cap then press in the grommet.
I only need one (set) to replace a lost on at someone’s house. I should have taken a picture!
It looks very much like this except it's shiny black plastic and it's two pieces.
Like this? http://www.harborcitysupply.com/detail.aspx?ID=553
Very close, but the one I need is full cirlce and two pieces.
You buy two of the pictured pieces. Together they make a full circle.
Hafele sells those in a multitude of colors and a few sizes.....also Feeney. aloha, mike
