Just finished my basement at my honeys request. Sooo I had to put my band saw, jointer, tablesaw, etc. etc. in the garage. I can work out of there well enough but my concern is that in just a month or so I am starting to see some rust haze on the Jointer and the bandsaw plates. What can I protect them with that will prevent rust but also not leave a residue on the wood. I live in Chicago so salt air is not an issue. Thanks
I use paste floor wax, just make sure there is no silicone in it, if there is rust clean it off first with green scothbrite pads, I reapply wax after I finish a project, being a hobbyist that work for me. If you are in a bit more of a production shop you might want to do it on a more regular bases.
Thanks to all responders. I will be using the wax.
Insulate that garage! That is if you're alowed to keep your tools in it for much longer . . . Brian
Hey Mike,
I keep reading about not using silicone, and so I don't, but I also don't know why I shouldn't. I see in another response here that it shows on the surface. Is it that only, or are there other reasons?
--jonnieboy
The silicone can cause issues with the finish you apply later "fish Eyes" and such, if you use a silicone free wax even if you get it directly on the board you've cut your lipped blind dovetail drawer front into, you should be ably to get it off with some methyl hydrate. (Not sure how I know that) You have a good day Jonnie.
"even if you get it directly on the board you've cut your lipped blind dovetail drawer front into..."
Mike,
Yeees, what a strangely specific piece of information you chose to illustrate your point... Something like that could never happen though, could it?
Thanks for the information. And now I know. And I didn't even have to learn it the hard way!
--jonnieboy
johnnie,
Just to let you know, WD-40 does NOT contain any silicone either, so is another alternative.
I also use wax and rejuvenate with common household waxpaper. Just scrunch up a piece and rub down all surfaces, including the fence. Keeps buildup to a minimum but may require more frequent application.
Good ideas. Will try them.
Renaissance Wax, Boeshield T-9, WD-40. All safe, right?
-jonnieboy
Yup but all will need re-application/juvenation.
All tools need maintenance as you know. I thoroughly clean all my power tools and clean the woodshop weekly, just a habit I got into.
Very good advise.
Bob,
What's your experience, if any, with camellia oil?
Wait, did I just hijack this thread? ...No, I'm on topic (for once).
--jonnieboy
johnnie,
I've never used it so can't tell you anything about it. I've seen it recommended quite often in Knots though; often for carving chisels. For some arcane reason me pea brain doesn't like anythang on me carving chisels.
I keep them, along with planes and bench chisels in a heated cabinet so they don't rust at all; used a gun cabinet heater. The bees knees.
I used talcum powder and canvas covers many years ago with limited success. I then used SlipIt and HTC machine covers for years and that worked better. I now use Renaissance wax with HTC machine covers and I have no signs of rust in humid NE Ohio. I would recommend you try a HTC machine cover after you treat your machine tool tops. You need to cover your machine tops with a breathable cover. I usually get the medium size and use 2 on most machines to cover all surfaces. The last one I got is made in China, I hope it works as good as the made in USA covers.
Life is what happens to you when you're making other plans.
When your ship comes in... make sure you are not at the airport.
I second the floor wax. I've used johnsons floor wax for years and you'll know when it's time to redo the haze will come back. Just be sure what you use is non silicone or you will see it when you finish!
I was married by a judge - I should have asked for a jury.
George Burns
I use Topcote. http://wwhardware.com/catalog.cfm/ProductID/SATC11
Doesn't interfere with finishes.
and try to prevent some of that with a dehumidifer, i too live in chicago and have had no problems with rust
Edited 9/20/2009 7:53 am ET by Kenney66
