Getting ready to stain and topcoat exterior door. White Oak. Plan to use marine varnish for topcoat. Any thoughts about stain preference. I planned on useing an oil base stain. Friend said I should use an acrylic stain. looking for a little insight on the differences, good points and bad of both. As always any, and all input about different stain types in general would be greatly appriciated.
A regular pigment based stain should do fine. Now, I don't know what you're friend is thinking about, but the term acrylic - in coatings, refers to polymers in the paint. And acrylic is usually assosciated with paint, so an acrylic stain would end up being something like a solid color deck stain. Anyway, not a scientist, just thinking out loud here. If you're staining it, that's not completely unreasonable, I guess, but I would want to make sure ahead of time that you weren't going to have some kind of compatibility issue with the spar varnish.
But any of the readily available stains - Sherwin, Old Masters . . . should hold up reasonably well. Unless you're in direct sunlight all the time. Then all bets are off.
"If you pick up a starving dog and make him prosperous, he will not bite you. This is the principal difference between a dog and a man." - Mark Twain
I would stick with the oil based stain as you planned. You COULD use an acrylic stain under your oil based clear coat but I can see no advantage in doing it that way. I think you'd be less likely to run into trouble with your original plan.
Thanks RW. Thanks Clay. Oil it is.
