I made a knife handle from a piece of ash. I had smithed the knife itself from an old rusty chisel so it was black smith black and I wanted to keep that look. I though why not ebonize the handle as well. A while back I had put some white finegar and steel wool in a plastic jug to make my ebonizer. The steel wool is gone and I have a quart or so of redish brown liquid. So I soaked the Ash several times and was only able to get a sort of light effect with a slight greater affect in the grain.
I take it Ash does not ebonize well? OR do I need to prepare it differently? I had finish sanded the ash on the lathe with 220
It appears that your ash has less tannic acid than oak. You could tink with applying tannic acid solutions to increase the effect, but I don't really recommend that.
There are much better ways of ebonizing wood than home chemistry experiments. Aniline dye is quite effective, and you can find dyes with a cool black or warm black hues. This will go over your iron buff treated wood.
