Good day to all. First of all I would like to thank every one for their suggestions and advice.Now back to my question of the day.I just came back from the Brownsville Texas area and noticed on the old and new houses being built that they weren’t installing eaves troughing and were still using lumber for the fascia and soffit. Can anyone tell me their reasoning? I thought maybe it was because of hurricanes, because of it being a coastal area and high winds.I also noticed a lot of rot on the fascia,from all the water.I know There are many new materials out for these applications,and thats what sparked my curiosity.
They might be trying to prevent ice dams ;-) Nah.
Sorry, couldn't resist.
Bruce S.
Edited 5/24/2008 9:35 pm ET by BruceS
This is better asked over at the Breaktime forum, (that's Fine Homebuilding)
Is "eaves troughing" what we would call gutters here in the northeast?
John White
Yes, the terms are synonymous. Eaves trough is probably an older term.
Edited 5/26/2008 11:22 pm ET by Tinkerer3
In the interest of full disclosure- I Googled to make sure
they were the same thing.
I live up north so I don't know about hurricanes and such.
One thing I've noticed is people have begun to think of them
as unsightly.
Me I'd rather pitch the water off my house, but each to his own.
Gutters aren't a necessity as long as you drain the water away from the house once it reaches the ground. Gutters are also an expense to install and usually an ongoing maintenance problem. Fascia and trim rot because they were installed incorrectly, usually a lack of flashing and proper sloping are the cause.
John White
Oh there are times you need them.
Multiple roof lines often dump on one another creating splash back that rots siding.
Doors, can be subjected to undo water, and under the door is the first place a sill rots out.
The grade often doesn't cooperate.
I often think back to the old timers when it comes to dealing with common building problems. Their solutions are simple and effective.
John,
Then they'd be called eaves dropping?
It's called "cheap." Builders don't put on gutters because it costs money. Many of the homes not only have rotting wood in the eves. They often have problems with the foundation and water damage to the wood just above it. I find it amazing that gutters aren't required by code. They have a lot of other things that are required that do far less.
