When turning pens I want to make a red blank, but I don’t have any red wood on hand. Is there a tip/trick to dying the woood? Thanks in advance for your help.
Bio
Bio
It will be much easier, and better looking, to buy the proper wood. Redheart, padauk, or bloodwood pen blanks are available from many vendors and are very inexpensive. Try WoodTurningz.com for one. Inexpensive and a great selection. Red acrylic blanks are also available if you want to try something other than your requested wood blanks.
Bruce
Thanks. I think I may have some of those in a grab bag from Woodcraft.
I use analine dyes and turn pens. I don't see any problems with dying a solid wood pen blank. I'd apply the red dye in the finishing stage after it's been turned and sanded to completion.
Do you just apply it like you would your finish or would you let it soak?
I would apply it with a rag and let it dry before proceeding. You can't prevent it from soaking in. I'm sure that your top coat is not water based, so no problem there.Chris @ http://www.flairwoodwork.spaces.live.com(soon to be http://www.flairwoodworks.com)
Thanks.
