Hi.
I’m sure this has been covered, but couldn’t find what I’m looking for with a quick search.
Controlling dust.
So I’ve made a beautiful piece which I want to finish with a stain , dye, sealer, etc. Multi-function shop, two rooms; one ~11 X 20, other half as long. Most things move easily. Need to build, prefer temporary or at least portable, finishing booth up to ~ 4’w x 4’d x 6’h. Adjustable as needed. Frame, plastic? Removing existing dust? Open and close w/out adding dust? Can usually be in room not where less sawdust made. Air cleaner helpful? Got a old one.
I am not a finisher .. Look/search Negative air flow?
It's a very challenging task to get rooms clean enough to avoid dust on slower drying finishes such as oil based varnishes. I've done lots of things, but have reached the point where I just work in a clean space without stirring up dust, and expect with certainty that I will have to rub out the finish to remove dust nibs. If that's part of the plan from the beginning it's only important to avoid major dust contamination.
I've also had several finish rooms that were OK, but not perfect. It's not so easy to get real dust-free conditions anywhere near a normal shop. I don't think you really want to go all the way with this, but FWIW, the best spray room I ever had is undoubtedly my current one, and the principle is this:
There is no exhaust fan for the room; on the contrary, it is pressurized by forcing air into it, and the excess just flows out (through baffles)from vents at floor level. The incoming air is well-filtered and comes from the ceiling, creating a downdraft throughout the room, which carries any overspray down and then away. Because the room is slightly pressurized, opening the door to enter causes air to blow out and not let dust into the room. Even with all this, a certain amount of overspray gradually settles on the floor as dust, and prior to doing a critical gloss finish we still need to wash down the floor. And BTW, don't go into the room wearing the same clothes you had on in the shop.
David Ring
http://www.touchwood.co.il/?lang=e&id=1
