I want to make a mailbox for my 80-year old MIL whose arthritis and easily bruised skin make it difficult to reach down into a typical “top loader” to get the mail.
I plan to make a 15″x15″x6″ box to hang on the wall with a fixed mail slot at the top and a drop-down door in the front face so she can get at the mail easily.
Looking at Rockler and Woodcraft online, I don’t see any hardware to stop a 12″x12″door at horizontal when it opens.
Whatever it is must not intrude very far into the box where it might snag the letters. I know I’ve seen a sort of two-piece bar, hinged in the middle with one end fastened to the face frame and the other to the inside face of the door, but I don’t know where to find one or the proper name to search for it online.
Anyone have a good hardware source and/or a better idea for a mailbox door?
The hinged bar you describe is for a drop-leaf desk, usually. They have a couple of versions at Rockler. This page has all their Lid Support hardware. Click here for the solid brass drop-leaf hardware, or click here for the economy version.
You can extend the sides lower than the bottom of the box and hinge the door on hinges fastened to the outside bottom of the box so that when you open the door, it hits the bottom of the box and keeps it from opening farther. Hmmm. Harder to describe than do.
Mike Hennessy
Pittsburgh, PA
I'm sure I've seen these at our local hardware store.
Frosty
bruce,
Couple thoughts:
Check for room if you plan to use the desk lid hdwe, to make sure the slider has someplace to go when you close the lid.
The two-piece hinged, or folding supports might fit, but may be problematic, in that it would likely take two hands to close the lid- one to unlock the folding joint, the other to raise the lid, could be a challenge if your hands are full of mail already.
Butlers' tray hinges, tho a little costly, have a positive stop/support built in, both open and at 90*.
Common hinges, plus a length of light chain attached to one side of the box and slightly inboard on the lid, might be the simplest solution.
"The two-piece hinged, or folding supports might fit, but may be problematic, in that it would likely take two hands to close the lid- one to unlock the folding joint, the other to raise the lid, could be a challenge if your hands are full of mail already."Thanks for that observation. I'll have to see if that's the case. Since she has severe arthritis, any complication of use would be magnified greatly for her.
BruceT
Take a look at quadrant hinges, they come in several different sizes. http://www.ahturf.com/catalog/itemdetails.phtml?ss=b%07QH-5%07c%07%07a%07S%07e%071%07f%0736384%07z%072b38 Chris
Thanks. I considered those but they look like they would intrude pretty far into the box and perhaps interfere with items of mail.
BruceT
Hey Bruce, the hinges are fully mortised into the box sides, so they would not intrude at all into the interior of the box. Chris
Where does the quarter-circular stop go when the hinge is in the closed position?
BruceT
Hi Bruce it goes into a mortise in the box side. It always help to see it visually. http://www.whitechapel-ltd.com/tech/quadrant_hinges.shtml
Thanks.I had in mind an inset door, so of course I could not picture how a quadrant hinge would work.
BruceT
"Since she has severe arthritis, any complication of use would be magnified greatly for her." I'm wondering.....would it be possible to design the door to open when pushed, the way glass doors on entertainment centers do. That way, she could use the side of her hand, rather than her fingers, to open it. The trick would be getting the door to drop down gradually, not clunk down suddenly.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
"..would it be possible to design the door to open when pushed, the way glass doors on entertainment centers do. That way, she could use the side of her hand, rather than her fingers, to open it."Interesting idea. Touch latch would be easy to open. I had been thinking of a bullet catch so there would be no interference with the mail dropping in through the slot.
BruceT
I don't have arthritis, but I have had varying degrees of tendinitis in my hands; there is probably some common ground vis a vis symptoms and pain. My thinking is that grasping or manipulating with the fingers would be more painful than just pushing with the outside of the hand, or even some part of the arm.
Wish I had a magic answer about the dropping-down part....forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
maybe a shock like the ones for the back doors on mini vans. i know they make small ones, i just don't know where you can find one.
Just a thought, but most of the supports are designed to carry far more weight than you're dealing with here. Have you considered conventional hinges at the bottom of the door, and a length of small chain (bead or small brass links) on each side? If you wanted to get fancy, the chain could even be countersunk into the edges of the box frame.
Thanks, you and joinerswork have suggested the same solution. Sounds like the simplest and cheapest way to go and, as you say, plenty strong enough for such a small door.
BruceT
Thanks again, everyone, for the help on my mailbox drop-down door. The simplest solution, a length of chain, was just what the doctor ordered.
I thought I'd post pictures of the final product as well. I still have to patch the mortise where version one had a simple ball catch. MIL was worried that someone could steal her SS check, so I installed a lock yesterday.
PS: I installed the front door, jamb and sill for her in August and made the trim of the mailbox door to evoke those raised panels.
bruce,
Well done! That box looks as good as if you'd done it.
Thanks again for the chain idea. I was fixated on complicated hardware that wouldn't have worked as well.BruceT
bruce,
Glad it worked for you.
Nicely done, Bruce. Very classy looking.
Wow, very handsome! forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)
