What are your thoughts on the use of the drill press as a pin router?
Is it safe? I don’t see why it would necessarily be more dangerous than a pin router. My old RAS had an attachment for a router bit so that I could use it as a pin router.
I’ve got an old Rockwell standing drill press that I’d like to use as a pin router.
Thoughts..?
Experience..?
I tried to use my drill press once as a router (upcut spiral bit), and the bit pulled the chuck out as soon as it touched the work. Haven't tried again. If I ever have trouble getting the chuck out, I know what to do.
Or do you mean to use the press to hold the pin and have the router mounted underneath?
ne sutor ultra crepidam: Disputantum Semirotten Woodworking
Edited 3/10/2008 2:36 am ET by Disputantum
I've tried to use my DP as a router, but it doesn't have the RPMs to get the job done very well. It also generates a lot of chatter. YMMV. Can't hurt to try. I'd just set it up with a bit with a bearing and see if it works well enough for you. If so, go for it.
Mike Hennessy
Pittsburgh, PA
Bad idea as others have mentioned. A jacobs taper on the chuck will easily come out. Like to have a spinning cutter in your lap. Some drill presses had a threaded chuck and it's possible to do some limited router work but there is a lot of chatter.
RPM to low
These are much better options for a pin router. I've used pin routers extensively the drill press is a sorry version of a pin router.
http://www.leevalley.com/wood/page.aspx?c=1&p=43039&cat=1,43000
http://grizzly.com/products/Bench-Top-Overarm-Router/G0587
... Well I guess that settles my curiosity.
However, if the RPMs on a drill press are too low, does that mean that when I have the belt mounted for top speed the RPMs would still be too low?Thanks
You can answer your own question by looking at comparable router speeds. 20,000 is typical for a pin router. Most drill presses are 2,000 max, it varies with each manufacturer.
I will give you bonus points for at least knowing what pin router is.
Edited 3/10/2008 11:38 am ET by RickL
I have a X-Y table on my DP and thought I could do some light milling but I get way to much vibration as DPs only have one bearing at bottom and top of quill just floats in a loose fit so you have no side to side stability...
Also I dont think your DP can make 10,000 rpm let alone 30,000 :)
