Morning all:
I have raved about my domino before and here I go again. I use it to align boards in a glue up- works great; I use it, in almost all cases, instead of traditional mortise and tenon joinery- works great. Found a new use for it yesterday. Don’t know if this is original but I had a need to cut elongated screw holes for a cleat I was putting on the leaves of a drop leaf table. Was going just to use different size drill bits as I have in the past. Instead, used 5mm domino bit to drill through the cleat and then used 10mm bit over previous hole perhaps half way through the cleat. The result was an easy, neat elongated hole. Try it if you want. Thought it might be helpful to domino owners. pmm
Good idea! Thanks.
Better life through Zoodles and poutine...
I love mine as well. Great tip. Be sure to go over to the FOG site and share there.
