I want to create a dished area perhaps 6 – 8 ‘ in diameter and 1/2 – 3/4″ at it” deeepest point in an otherwise flat surface. The “dish” will be extremely off center to the field so a lathe, even if I had one, would not work. I have two aplications in mind, one is for an hors d’oeuvres tray the other for a shushi tray. In both cases the dished out area will hold a shallow bowl for dips or sauces. Any experience or ideas on how to do this? Woods used will be maple, cherry, white oak, ash or white oak.
Use a template guided router and a core box bit or a bowl bit. Here's a picture of one in use on a more complex pattern.
http://www.woodmagazine.com/woodmag/133/images/template-lg.jpg
Edited 3/15/2003 8:53:47 PM ET by Uncle Dunc
Hi! And thanks for your response. Perhaps I'm slow but it isn't readily apparent to me how that jig creates a bowl shape. Is there a site I can go to to get more info?
I think I must have misread your description. The technique I described would give you a recess with vertical sides and a radiused transition to a flat bottom. For a continuous curve bowl shape, the other respondents have offered better techniques.
Know anyone with a CNC router? If this is for a production product that would be the only way to go, provided you want to make money.
If this isn't going to be mass produced you could always use a fishtail gouge to carve it out. If you want to smooth it out after you could use an inshave.
One more idea that may or may no work is to make a jig with a lazy susan bearing that would allow the work to rotate while you plunged a router bit in from above. Having an overhead router would be nice here, but it wouldn't be too hard to build a makeshift one with a plunge router.
Hi,If your not adverse to using hand tools, there is an old tool called a "scorp" which is used in chairmaking to scoop out a depression in the seat. There is also a plane called a compass plane used to do the same thing. It has a convex bottom. Brian
PS.. a scorp, if your not already familiar, is a curved draw knife and fairly readily available.
Brian, thanks for the input. Since this will be at the most a limited run project I may need to go the hand tool route. Nothing wrong with that just not experienced. BTW you wouldn't be a graduate of HCC would you?
No, Didn't graduate from HCC...and now very curious. HCC?
Don't know about a scorp but why not a simple gouge?
Hi Toby, you're correct, I meant 6" on the other hand if you've ever been to an Indonesian reis (sp?) taffel 6' would not be inappropriate!
Edited 3/16/2003 11:40:52 AM ET by LIMEYZEN
Rijstaffel - Dutch for Rice table
A Dutch Indonesian banquet that gives meaning to the word EXCESS!
2 ideas -
1. Turn the recessed part in a contrasting wood and use that as a decorative feature.
2. Make a pendulum jig for a router. The jig should have a circular base which would then rotate in a piece of plywood with a circular hole cut out to fit the base.
Good luck.
Shane
LIMEYZEN
Two thoughts. First, this can be done on a lathe. Mount it on a faceplate and screw some weights to the "light" side of the faceplate to fairly well balance things, then turn at a lower speed. Of course your lathe needs to have a large enough swing for this or turn it outboard.
Second. Turn just the bowl on the lathe with a decorative edge and inset it into the other part by routing a recess, (round and flat bottomed) then glueing the bowl in. The decorative edge would hide the glueline.
Rich
The Professional Termite
