Howdy folks,
I recently made an impromptu steam bender for bending walnut molding. I made it out of whatever I could find in my barn, which includes a length of black pipe…more on that in a second…
To make a short story long, the walnut molding bent just fine…but was heavily blackened – not burned, but almost the color of ebony…
So…Did I steam it too long? do I just need to wait for a day for it to thoroughly dry out? Is this just what walnut does when steam bent?
(btw, the molding is 9/16″ X 7/16″ with an ogee profile. It has to achieve a fairly tight elliptical curve. And I steamed it at over 200 degrees F for 35 minutes)
As for the pipe, it’s an old steel pipe, and the water that collected was kind of dirty and, well, black.. So I’m leaning towards the dirtiness of the old pipe as the problem and will try a different pipe in a couple days..
I’ve read through a lot of the steam bending articles and plan on making a proper steam box at some point…but I didn’t see anything about wood discoloration.
What do you all think?
Thanks, Zigs
Edited 6/17/2009 8:49 pm ET by Zigs
The iron reacted with tannin in the wood to create the black color. I don't know if there's a practical way to remove it from walnut; it can be removed using oxalic acid bleach, but that will also bleach out the natural color of the wood.
Common woods most susceptible to this are walnut, oak, cedar, and, to a lesser extent, cherry.
Oxalic acid is what you want to remove the iron discoloration. It doesn't remove the natural color of the wood--it's not the same as the A - B wood bleaches (sodium hydroxide and hydrogen peroxide) that can turn walnut all the way to white. The other bleach used in woodworking is chlorine bleach which removes most dyes and a few other stains and also has minimal effect on the natural color of the wood.
Steel or iron pipe isn't the way to go. Your work piece has to be suspended above any condensed water that will accumulate in the steam box. You have deeply stained the walnut and there isn't a fix except to start over.
Thanks guys. Luckily this was just an imromptu test on one molding piece to see if we could achieve the bend. I plan on making a proper steam box with stainless steel rods as 'shelves' and some holes in the bottom to let cool air and condensed water escape.
Hopefully that will solve the staining issue.
Zigs
Edited 6/17/2009 10:20 pm ET by Zigs
Depending on the alloy, stainless steel can rust under certain conditions. If it can rust, it can discolor wood. Dowels to support the molding may be the way to go.
When I was bending a 5'+ piece of 1 X 4 maple a bunch of years ago I bought a 6' piece of aluminum gutter downspout, plugged the ends with a hole at one end to drain the water and hooked up the steam hose and had no trouble at all.
ASK
There is another way to bend walnut without steam. You can bend finished woods without harm to the finish by using oil - a high temperature vegetable oil, like peanut oil - and infrared heat lamps.
I use this to bend 150 yr old walnut gunstocks and it turns the wood to a very rubbery consistency quickly. The finish is unharmed when the vegetable oil is wiped off.
Brent
You do have to be more careful about overheating and burning the wood when using oil, though. That's actually one of the main reasons for using steam: it limits the maximum temperature to a little below the boiling point of water.
I suppose that could true, though I am hard pressed to see that as a problem. It has not been the case for me using easily regulated lamps. I have never heard of anyone burning or even blistering the finish on an antique rifle.
Brent
I think all is well.. I am not into making wood as some plane sheet of glass you look at and see through..
Wood is wood and as it should be. Like a Man and Wife that love each other.. May not get along sometimes... But mostly do.. All that counts.. I'd say that perfect finish in wood is Artificial and will always be that..
brent,
one does not merely COMPREHEND our beloved will, one needs to FEEL into his meanings. hang in there. be patient with yourself. soon you will come to treasure his lovely articulations and wise words. his posts always make the knots experience richer.
eef
Oh...
I think I need a beer.
brent,
i'm buying.
eef
