I’ve read complaints about perforated diamond stones rusting when lubricated with water. I’ve read some people who use them dry. And I’ve read some people use various light oils.
Can anyone decrease my confusion? Thanx!
PS – I just got a DMT Duo perforated stone (extra coarse and coarse) and a DMT continuous stone (fine)
The Wood Loon
Acton, MA
I've never seen a diamond stone rust. As far as I know, the backing is nickel, which doesn't rust. What I have seen is rust stains on a diamond stone, not from the stone itself, but from the steel swarf removed from whatever it is you're sharpening. Those stains can be hard to remove, but they're not indicative of any harm coming to the stone.
I'll sometimes use a diamond stone dry when sharpening a pair of scissors, a gardening tool, etc. But I usually use water with woodworking tools, not so much for lubrication (although there is some), but rather for dust control.
I second Steve's reply.
Hi Doug
I have the 10" DMT Duosharp. The Extra Coarse side is used to flatten my waterstones so, as you may expect, it get wet a lot! Sometimes it lies in a wet state in preparation. There has never been any sign of rust in 18 months of use.
Do you use your diamond stones to sharpen your hand tools, if so which ones work best?
WD
I do not/cannot "sharpen" blades with diamond stones as mine only go up to 1200 grit (extra fine). The Coarse - fine might best be considered grinding media. They prepare the surface for smoothing waterstones, or do the initial preparation of the backs of blades. I have used, on the other hand, diamond paste up to .5 microns, but that is a different issue.
Nothing hurts the diamonds.. The binder counts.. Why not ask the folks that made them!
per the instructions on the packaging from DMT on the stone I bought, use only water, nothing else. I don't know what will happen if you use something else, but I suspect it might break down the binder that holds the diamonds to the plate.
Rizzo the Rat, A Muppet Christmas Carol
I use water on mine (3M and a DMT) They have some stains but it does note seem to effect the way they work. When I am done with them I scrub them off with an old kitchen sponge with the course surface. and let them dry. Hope that helps.
Troy
Thanks, all - you've killd my fear of water!Doug
The Wood Loon
Acton, MA
