A friend asked me to repair a small table she had received from her Mother: the top was cracked.
Whoever had produced this monstrosity had joined 2 – 3/8″ pieces to form the 3.4″ top – but they were cross-lapped, I suppose to keep the top from cupping. With cross grain glued to long grain both sides failed.
Frosty
“I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm.” FDR – 1922
It's not a monstrosity, just a novice's mistake. Dog knows I've made my share. I made a doozy once way back when.... How you gonna fix it?
Sapwood and DoorboyThanks for the suggestions - my choice was/is to SCRAP it. Now comes the rest of the story: I made a really nice new top. 3/4" thick, of maple. Applied Dark Mahogany Transtint WB dye; 1 coat of shellac. Then a Deep Red Mahogany glaze, followed by three coats of WB Poly (There might be an alcoholic spill on the top)When I mounted my new top on the sub-top I used 1 1/4" screws.
(3/4" sub-top plus 3/4" top = 1 1/2") You're ahead of me already - the 3 screws came through the face about 1/32" ! I guess the countersinks were deeper than I thought. I tried to patch it but was never satisfied with the qua;ity of the repairs (shellac stick) so I just finished making a second top.Frosty"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
It must have looked a good idea at the time. If you're soliciting ideas on how to fix it, then my opinion is to leave the splits alone, but insert a couple of butterfly joints to stabilize it and dress it up a bit.
Frosty,
That looks like an early design for a manhole cover. As they evolved, they went to a round shape. Do you know why? Think about it, then scroll down.
Because that is the only shape of cover that cannot fall into the hole.
I hate to admit it, but I didn't know the answer when first asked.
Ask people that at a party. You will be a big hit (if everyone there is an engineer).
Mel,
Now, do you know whay they call 'em manhole covers?
Bob:Now that's easy. The purpose of the shaft is to provide access for maintenance and repairs. The shaft was always big enough so that a man could get down, hence man holes, hence manhole covers.Today, of course, they would be called something else because of the sex thingy. Or is it gender? Though gender is a linguistic term - not biological. A Monsieur Table would have a noun whose gender is feminine, but his sex would be male.Regards,Hastings
Hastings,
They would now be called "Person hole covers."
I have a list of other non sexist words which eliminate the term "man".
Think of:
compersonned
persondolin
persondate
Personilla (name of a place)
persondatoryThe list goes on.
The water disrtict I worked for and the other local entities all agreed to just call them access ways, utility access entries, or utility access points. Everybody out in the field still called them manholes.
My favorite silly name was HMI, which stood for Human Machine Interface, which is a really long way to say on/off switch.
I'm an engineer - I figured it out - but I don't know the answer to Bob's question.Frosty"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
jfrostjr
I'm not so sure I would condemn that approach. I suspect improper glue up or too green a wood as the real culprit.. My logic is that plywood is made exactly that way with slightly thinnner "boards" and it doesn't have a problem. Especially marine grade plywood.
You make a good point. But, perhaps plywood is stable because the plys are so thin they can't summon enough force to cause failure.This thing looks like it might have been assembled with VERY DRY wood and then, at some time, placed in a humid environment. Some of the cracks look more like 'upheavals'.But who am I to criticise? I made a screw-up too.Frosty"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
"But, perhaps plywood is stable because the plys are so thin they can't summon enough force to cause failure."
That's the key. Plywood is a battle between forces. The battle takes place along the shear plane--the glue--between two plies. The wood wants to move, the glue wants it to stay in place. When you make the ply thicker, you give the advantage to the wood (more wood, more shear force generated). Eventually, you reach a point where the wood wins, and the glue fails. That's the practical upper limit on ply thickness.
