Is anyone planning on being at the Design in Wood Show in San Diego next month? I was fortunate to have my Lily Pad Table selected for the show and I plan to be there for the judging on June 11th. I’d love to meet any fellow Knotheads that might be there.
Jim
Fine Woodworking Recommended Products
Foam Brushes
Foam brushes are great for applying a variety of stains and finishes, and the 2" wide brush is the most versatile. Comes in a pack of 48.
Delta 22-555 Planer
Knife changes on this planer were easy enough, except that you need an Allen wrench to open the dust cover and gain access to the knives, and it’s not the same size as the wrench used to loosen the screws that secure the knives. The 2-1/2-in.-dia. dust port can be reversed for use on either side of the machine. Two material rollers on top of the machine aid with transferring stock from the outfeed side back to the infeed side. Finally, there is no gauge that indicates how much material you’re about to remove, a convenience that three other planers also lack.
Dividers
Incredibly useful for laying out, setting equal distances, and comparing measurements, these are an essential tool for any furniture maker.
Mirka Direct Electric Random Orbital Sander 5-in.
- Excellent dust collection and stock removal. Must be used with a vacuum - The paddle switch was awkward to use, but the shape of the head made handling - Comfortable with one hand or two - Stops very quickly.
Festool Model KS 120 REB Miter Saw
Sliding compound miter saws have become a woodshop staple. Their ability to squarely crosscut wide boards and to cut difficult miter and bevel angles is huge. Festool’s Kapex KS 120 REB fulfills these duties with aplomb. The design keeps the saw close to the wall, allowing for a small footprint. The cut is rigid and precise provided you use good technique. It accepts 20mm blades, about 10 1⁄4 in. Its maximum width of cut is 12 in..
show
Congrats on having your table selected, Jim.
