I just finished setting up my new Delta 10″ RAS and went to change the voltage to 240 and neither the photo in the manual nor the description are what I am seeing on my saw. I have looked for this “voltage switch” in the motor wiring box, which just contains capacitors, in a silver assembly attached, which looks likely, just wiring to move instead of a switch to flip, and even checked out the front on/off switch assembly, but still no 120 / 240 switch to flip.
Does anyone have updated info on this saw.
Edited 1/6/2008 10:46 pm ET by kringleklaus
Edited 1/6/2008 10:47 pm ET by kringleklaus
Read the motor plate on the front of the motor. It will tell you what voltages it's rated for. If it only lists one voltage than that's the only voltage. There is no voltage switch. Typically you have to change wires if it has dual voltages.
