At my local tool store today, I found a Delat 31-250 drum sander in the used section. It was priced at $800, and the guy offered to knock it down to $700. It was in immaculate condition, like new. Apparently, the prior user had never used it much and traded it in for the big General 20″ drum sander. So I bought it.
Once home, I started doing some research into this purchase and am concerned with what I am seeing – lots of negative reviews as well as some good ones. I don’t know whether the negative reviews come from people trying to use it as a THICKNESS PLANER. I have three days to return it if I don’t want it. I will try to get it set up tomorrow so that I can try it out, but does anyone have any experience with this unit?
Chris @ www.flairwoodworks.com
and www.flairwoodwork.spaces.live.com)
– Success is not the key to happiness. Happiness is the key to success. If you love what you are doing, you will be successful. – Albert Schweitzer
I had one and it worked very well for me. I upgraded to the Shop Fox 26" dual drum sander to get the benefits of two grits in one pass, but the Delta was a trouble free machine that did a good job.
If you have difficulty raising and lowering the table drop me a note and I'll run you through how to set it up.
Men will never be free until the last king is strangled with the entrails of the last priest.
~ Denis Diderot
I got a used one several months ago, use it mostly for sanding down re-sawn veneers from the bandsaw. You have to be patient with it, try taking a little too much off and it grinds to a stop. And putting on new sandpaper is a pain, it has to be just the right angle and tight. Other than that I love it, saves me time and money because I used to have to drive 15 minutes to a cabinet shop and use theirs at $30 a pop. One of the woodworking mags had a great article about 6 months ago showing a bunch of tips for using drum sanders, wish I could remember which one. If I find it I'll send you the link. You also gotta make sure you have plenty of suction to remove the sawdust!
You have adressed your reply to the wrong person.
I forgot to mention that if you get a chance to pick up the outboard inflatable drum sander attachment do so. It is very handy.
~ Denis Diderot
I've had one for a couple years and love it. always performed well and was a better deal than the performax.
I set it up, once, when i bought it and adjusted the table to within a couple thousandths parallel over its entire width. it hasn't moved on me since. i haven't experienced any of the commonly reported issues with this tool (table hard to raise / lower, cant get it parallel to drum) and assume they are either caused by a few bad units or operator error. either that or i am just lucky. whichever, it has performed great for me.
the setup / adjustment was very straightforward.
After having sold a large number of these, I am convinced that the problems were due to operator stupidity. I'ts a nice machine as you said.
I've had mine for about 3 years now and its had no issues on its own. People will be dissapointed if they think they can use it as a jointer. I will say that if the main table gets out, it's a bear to get back in. When the movers moved me the last time the put something on the table and caused it to get out of alignment. I spent several hours getting it back cutting flat. I would reccomend putting casters on yours if you have not already. I caught woodcraft with a sale on the good locking ones, and put them on. It makes it nice to slide around. I sure hope you have a DC, you will fill up your lungs if you don't.
The nine most terrifying words in the English language are, 'I'm from the government and I'm here to help.' - Renaldus Magnus
Thanks to all for the feedback. It seems that the negative reviews came from those expecting too much from it (planer). I set it up yesterday and it took a while to get the belt to track. In the end, the left side needed to be very loose and the right side tight. But it tracks well. I will need to adjust the height, as it sands a little deeper at the left. I will be keeping it. I have a pretty good dust collector and it works well with the sander. I haven't quite figured out mobility yet. I may drop it on castors or mount it on slides to pull out from a cabinet. I don't anticipate using it a lot, but know I will really be glad I have it when I need it. I've already been asked how much I'd charge per hour for use.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
