Can anyone give me a run down on the differences between deft’s water based acrylic and crystallac. Need to spray some cabinet interiors (no fancy spray booth!) and am not sure which way to go. Both seem fairly easy to spray but am unclear on how the two are different.
Chris
Doesn't look like folks have experience with both. You can expect them to be fairly similar--both being acyrlic resin finishes. I suspect that for cabinet interiors either would accomplish the task. but I can't comment specifically.
One of the Crystallac finishes ( Premium Gloss) was rated in a FWW article in 2006, but the Deft was not, and the three years later the Cryltallac formulation may have changed, or for that matter, since there are several Crystallac finish varieties may not be the same at all.
Thanks. WIll try a different tract...
