I think, I read that you can not overheat HSS with grinding ?
Given that, if I wanted to make a tool and needed thicker stock could I silver solder/braze to pieces of thinner steel such as Sawsal blad, to make a thicker piece of steel? or put a reinforcing web/spline on?
Then shape to final size and shape?
This one has been bugging me
Wintershoe
You can buy tool steel but even easier is to use an old planer or jointer blade. What exactly are you trying to make???
