cutting molding while it’s still attached to wall.
I’d like to cut a piece of horizontal, floor-level molding without taking off the whole strip of molding and cutting it on my table saw. I only need to remove a few inches to allow a vertical piece of molding to reach the floor.
Will a multi-tool make a clean, straight cut in the molding? Will a dremel? Which would you use? If neither, what would you do?
Many Thanks. Paul
I run into that situation all the time doing installations. My first choice is to remove the molding. This eliminates all kinds of problems, is the easiest to do and results in the most accurate cuts. Of course, since I've done it so often, I know how to remove and replace the moldings without damaging them or showing signs of what was done (most of the time). I would use my miter saw but used to use a handsaw or hand miterbox before power miter saws were invented.
My second choice, is to use my Fein Multimaster with an E cut blade. I score a cut line with a sharp utility knife and cut a bevel on the waste side of the line. This makes a nice straight groove for the blade to sit in so it doesn't wander or jump out of the cut. You have to be careful not to cut through and damage the drywall or plaster behind the molding or make a visible cut above it.
My third choice and the one used before there was such a thing as a Multimaster still starts with a scored and beveled cut line. The rest of the cut can be done with a sharp chisel. Tap in straight lightly, then cut in on the bevel to meet with the straight in cut. You have to go slow and easy taking a small bite at a time. If you pound and get impatient, you may crack the molding or the wall or pop screws in the wall. The last 1/8" can be finished off by scoring with the utility knife, again lightly and with control. You don't want to slip, cutting yourself or something on the wall. Even with the Multimaster, you may have to finish the bottom of the cut with a knife and chisel to avoid damage to flooring, carpet or the molding.
The key to doing this is being patient, deliberate and using sharp tools carefully, like a surgeon. Most folks try to rush it and make a mess. Whether you use a machine or do it by hand, you have to take the time to go easy.
Hammer 1, one last question. Is your answer the same if the molding is mdf rather than wood?
Thanks again, Paul
MDF?!!!? isn't that illegal, Paul? Just kidding. MDF will cut a little easier than most species of wood, the density is consistent and it won't split. Scoring a cut line and beveling for a cutter to fit in will usually mean that you have a good straight edge for other things to fit against, regardless of the material or what you use to finish the cut. MDF won't hurt your tools any more than wood, if that's what you are worried about.
Once again, THANK YOU, Hammer! Paul
