Gentlemen:
I just glue up a panel made of red oak and it cupped.I laid it on two sticks and put a heavy cinder block to get it flat ,which worked.
My question is what to do to prevent it from cupping again?
Gentlemen:
leom
There are many factors about the properties of wood that can cause cupping. Just a few are:
And the list goes on and on....
I don't know you're experience level, but learning about the properties of wood would be a great place for you to start to avoid this in the future. The good news is that most of the time, you can reverse the problem, as you have. However, there are times, especially with reaction wood, where the symptoms are irreversible.
Have fun.
Leom ,
Well , is it a panel that will go in a door frame or be held in place by other parts ? Usually once a door panel is in the frame it's movement is restricted by the frame , the panels can shrink anf grow but typically stay flat.
So , get that panel in it's frame.
good luck dusty
