I am in the process of building Garrett Hack’s Huntboard which was featured in FWW #187 which many of the members here are likely familiar with. I am having a hard time finding a match for the inlay cuff banding usind of the legs. Any suggestions where I might find it? Thanks in advance.
The banding for that huntboard is very simple, made from alternating strips of dark and light wood; probable ebony and holly. As you can see in the article it is shop made and fairly thick, looks like about 1/8" to me. If you are going to take on such a project you should have no trouble producing your own banding.
ww,
As Bob suggests, you can make your own, by sandwiching (laminating) contrasting slabs of solid stock and/or veneer, then slicing off the edge of the sandwich to get the strips of banding. Some yokel named David Ray Pine even wrote a how-to article , I bet it's in the archives- I'm telling you, if he can do it, you can! You can match what is in either article, or get creative.
Alternatively, you could purchase some store-bought banding ready-made. The old timers frequently did just that. It doesn't have to match what the author used, necessarily.
Ray,
What issue was the banding article in? I thought I had seen/read all of your articles.
Every time, I turn my thickness planer on, I think of your glazed door article, or more accurately the passage in that article on how for maximum accuracy, you should run the stock through the same place on the surface planer.
Of course, I believe I told you before, but your fret work article is my all time favorite FWW article.
Rob Millard
Hi Rob,
It's in #59, the one with the pool table on the cover.
Thanks for the compliment, now you've done it, none of my hats'll fit .
Best regards,
Banding
Hello!
My name is Freddy Roman and I make custom/period banding for furniture makers. Now is the banding easy to make?.... Yes. Yet now you have to buy veneer and research how thick the veneer is, figure out how much you need, pay shipping, stress over the whole process, etc. etc. Even John and Thomas Seymour bought their banding . So if your interested please contact me @ [email protected] or call me @ 860-670-2584.
Cheers,
Freddy
Cuff banding
I was fortunate a couple of years ago to take a workshop with Garrett Hack and we made the banding and did some string inlay.As someone said, it is easy to make. It is alternating strips of ebony and holly glued up into a large blank and then pieces are sliced off,cut to size, and then glued into recess routed into the legs. You really should give it a try. It's easy and a lot of fun.
Pat
