I am undertaking the repair of a set of Chippendale style DR chairs. I need to replace several crest rails, and have been told that they should be sawn from thick stock rather than bent. I would appreciate advice as to grain orientation in the stock from which I saw the rails. Never have tried this before.
Chippendale style crest rails are always sawn from the solid. Grain running side to side, perpendicular to the back legs and splat.
Thanks Calvin.
Does it matter how the grain is oriented relative to your back touching the rail- quartersawn, riftsawn, etc??
Somebody may have a different opinion, but I don't think so. I would choose based on the appearance of the show face. Straight grained material here would be good in most any situation.
great. thanks a million.
delaunj,
"Does it matter how the grain is oriented relative to your back touching the rail- quartersawn, riftsawn, etc??"
This will affect the appearance of the crest rail. Sawing the curve into flatsawn stock will cut thru the growth rings, giving an appearance sort of like: ))))X((((( or
((((0)))) , depending on if the rings are facing towards or away from the face. Rift or quartersawn stuff will show the growth rings as either slightly curving (if riftsawn) or straight lines (if quartersawn) along the length of the rails. If you want to match the appearance of the other chairs in the set, select your stock accordingly.
Why did those crest rails fail? I want to make a rocker for DW and avoid pitfalls
The chairs are mahogany, probably fifty years old. It looks to me like they were probably cut from plainsawn stock. I want to avoid this happening again, although if they last another fifty years I don't have anything to worry about I guess. That's why I was thinking that a quartersawn face might be stronger.
Just make sure you choose a board that matches the rest of the chair. DAMHIKT
A picture speaks volumes, doesn't it. Great work, though.
Adam,
At Virginia Craftsmen, we used to say about occurrences like that, "Don't worry, the touch-up man will get it."
