I need to create some cove crown molding in soft maple. I don’t want to use the table saw method because of burning and all the sanding and scraping. I saw a horizontal router bit in a catalog where I could lay the board flat and move the bit up in small increments. Has any one used one of these and wath were the results. Also what was the brand of the bit.
I don't know why you would have a problem with burning a cove- that usually happens because of the sides of the teeth being in contact with the fresh cut. Making a cove is done with the tips and corners- there's no flat surfaces in contact at all. Plus, the blade doesn't need to hog out a lot of material and running it through after the last pass makes smoothing easier. A curved scraper with a good edge should work. If you want to make a form for sanding, a plastic bag filled with Bondo is a great thing.
#9 ,
Cutting a cove with the router sounds like a myth to me , I've never learned that method .
The reason you might get burns coving on the TS could be a dull blade or taking too large a bite at one time . Excellent results can be achieved on the TS a small amount at a time .
Cove cutting on the TS needs to be done very carefully , there is risk as in most any operation with power tools but this is one operation that's best not to rush .
good luck dusty
I've cut a cove with a bit from Eagle America. It worked just fine. I used it with a single trough for a crown molding, and with two troughs to flute the face of a column. It was clean enough to sand out by hand without even making a matching sanding block.
