I have a Bosch 1617 router, and I think it is a very good performing machine for a midsize router, but the problem is that the motor housing gets stuck in the base. When I manage to get it out, I notice that the motor has a corrosion on it. It’s not rust, and although I can take some silicon sand paper and get it to go away temporarily, it keeps returning.
My shop is climate controlled, and I have not had a problem with any other tools. I have tried wax, and Top-Cote, but neither seems to do the trick.
Has anyone else experienced this problem, and found a solution?
Any suggestions are appreciated
Peter
jpswoodworking.com
I have a 1618EVS and had the same thing happen to me. My shop is climate controlled and no other router (PC or DeWalt) has shown any signs of corrosion or rust.
Not sure if there is a fix or if it is a problem witht the magnesium housing.
I have the same problem as you. I have tried silicone spray and also wax but the corrosion reappears. No problem with any other tools.
Edited 11/22/2004 3:47 pm ET by Garry
I have the 1617evs. The housing corroded on mine too. Bosch replaced it under warranty and I was told that the problem was fixed and newer housings wouldn't corrode. I assumed they changed housing materials, although when I got it back from Bosch it looked like the same old material. The new one also corroded over time. I used sandpaper or scotchbrite pads and wax to clean it up. I don't know what else to do about it. it's pretty annoying, though. Stuff costs too much money to have fundamental design flaws like this.
Erik
Thanks for the infor Erik. I agree that these tools cost too much to have to put up with these annoyanses. I will contact Bosch also about this.
I purchased a Bosch 10 inch sliding miter saw awhile back. When I was setting up the saw I discovered the shotrt aluminum sliding extention fence would not line up with the stationary fence. I had to file the ways about 1/8 inch to get the fences to line up.
I guess I am heading back to Makita for future purchases. It's too bad because I really like the router conviences, the saw is nothing special.
Garry
http://www.superwoodworks.com
Thanks for mentioning this, whoever it was! I have the same router and thought the problem was just something I had to live with. Now I've contacted Bosch. We'll see.
Bosch has acknowledge this problem. Contact them to see what they will do about it. I have heard that they are replacing some routers.
It is funny when some one brings something like this up. I too have that router, and have the corosion problem. I never really thought much about it as I don't really use it very often. Now you bring this up and everyone seems to have this "defect" as well. I'll contact Bosch tomorrow.
Thanks for bringing this up,
mike
The housing is magnesium, try mag wheel polish...
I have a couple of these routers and I love em.
RE: mag wheel polishThat's what the Bosch rep told me. I bought some, tried it, but in my case, it didn't help.
Make sure it's a Mag wheel polish - like mothers brand. Many people mistake mag to mean all wheels, or falsely advertise it for mag wheels. Most of todays "mag" wheels are aluminium. Vette's in the late 60's had real mag wheels, but aluminiun really took hold of the automotive industry because of the same problem we're having with these routers. Take a lot of elbow grease and a good polish for real "mag" wheels.
Good luck.
Yeah, you're probably right. I just went down the line at an auto parts store and picked the first polish that said "mag wheels", so maybe I got the wrong thing. Anyway, I returned the router. It seemed like some sort of engineering goof, and I just was not willing to fight that problem through the whole life of that router. Thank the good lord for capitalism and fierce competition.
Yep -- I had the same problem. I don't know if it was corrosion in my case though, since it happened straight out of the box.
My solution: I returned it, and got my $$ back. This is a nicely designed router, but I was just not willing to fight this problem.
Since we are talking about problems with the Bosch router, have you all experienced problems with the depth set on the plunge base. I got the 2 pak and shortly after , the depth gauge seems "bent", it doesn't set firmly on the ratcheted base but angles outwardly. Anyone else with this problem?
I've had a simular complaint, The depth stops don't sit solidly on the base. So when you use them you have to push extra hard to make sure that the stop wheel thing compressed all the way. Does that make sense? It is not prone to accuracy because of this. When I bought it I think it was the best in its class, after seeing the new PC set up I think it is a lot more refined. I can't really complain though, this router has served me for 2 or more years.
Mikeplease excuse my spelling.
