Can anyone help me with the correct name of the hinge that are used on a table that will allow the insert to fold together and then drop inside the table itself for storage. I’ve seen these hinges on outdoor tables. Also where can they be purchased. Thanks for your time.
Edited 3/22/2004 10:13 am ET by tommy
Want to take another shot at describing the function? The way I read your description, I've never seen a table that works that way.
Tommy,
You are looking for the hardward of a Dutch Leaf Dining Table.
The enclosed link is for a non-traditional Dutch Leaf mechanism. It should get you started.
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=862-991&LARGEVIEW=ON
Dan Kornfeld, Owner/President - Odyssey Wood Design, Inc.
Edited 3/23/2004 1:57 am ET by Jackie Chan
thank you but I'll try to explain myself a little better later on. weather a little warmer have to get some work done. thanks again.
Butterfly Expansion Table? Check out the article by Paul Schurch in FWW 94 (May/June 1992.
thanks for your support
