Has anyone ever resurfaced the ends of their cool blocks after they are worn out? I have many miles on my present ones and they have developed grooves from the blades. And yes, I have already used the other ends already. I really don’t want to have to re-order if I can recycle (regrind) them.
Thanks.
Frank
Sure, just sand them flat. If you are worried about grit, use a file. I use maple blocks, and a block plane.
According to the Olson website; They are one of the hard plastics, with graphite, and other synthetic lubricants in the plastic.
They may machine with regular tools. Try cutting a shallow groove in a side with just a sharp blade first to see if it cuts or not. If it is hard enough that you can't cut it with a blade, all you would do is dull your tools.
Carbide edged tools will cut it. You could build a fixture to let you run them through the router table, (my first choice). I would make a sled for the router table with a dado in it the width of the guide, and just a tad shallower than the guide so it will sit proud of the surface just a bit, (1/16ths). Then clamp the cool block in by screwing a piece of scrap down to clamp it in. Or, build one to let you run them through the table saw with a fine toothed crosscut blade.
If your not visualizing the fixture I'm talking about, let me know and I can sketch one up.
Well, Probably not the safest way to do it but I just held each block tight against the fence of my crosscut sled and just barely trimmed of the ends to expose a new surface. They came out just like new! For the angled end I just cut a scrap piece of wood on my slide saw to use as a jig for the angle. I like the idea of the router jig fixture - probably much safer. Thanks for all the posts!
Frank
The disc sander dresses them up nicely.
