I am searching for a substitute for contact cement that will not react with lacquer. I need to veneer surfaces on a large box that is already constructed. I am looking for something that will allow me to adhere veneer to the substrate with a dry bond, but will not react with lacquer, as contact cement does. I would like to avoid the PVA glue/ iron-on method, if possible. Any suggestions?
Katy
Traditional hide glue or try the new FSV glue.
http://www.joewoodworker.com/veneering/glues.htm
Contact cement is for paper backed veneer only.
Edited 3/20/2006 9:47 am ET by RickL
I have a can of 'green' contact cement (water based).
I doubt that would work with lacquer, but I don't know for sure.
