Hi,
I have been granted a chunk of cocobolo. It’s 36″ x 24″ x 1″ with one full live edge which has a nice 1″ stripe of sap wood evenly along it.
It’s cupped in the middle about 1/2″. It has about 4 through cracks about 12″ long all on different corner. There a few surface checks which I have no idea of the depth.
Some nice solor and figure but the surface it oxidized and a bit hazy. Comes alive with a little water.
I look at it and could easily envision either several smaller pieces for future projects or some how use it as one large plank. if I took the one large plank the cup certainly poses problems…
I guess this is the first piece of wood I’m letting make the decsion. Previously and still I design a piece and search the wood based upon my vision. Not so here.
So faced with such a task how would YOU proceed? Stabilize? Clean? Mill? Wait? Or???
Bro. Luke
Personally, I would put it on my lumber rack until I knew what I was going to do with it. As long as it has reached equilibrium (either KD or AD), the checks you've noted should not worsen. Since Cocobolo is a Dalbergia, a true rosewood, it's quite oily and would not accept much in the terms of stabilization (PEG or other).
Put it up on the rack, take it down every once in a while and look at it carefully and eventually, the right project will come to you.
good luck,
Jim
"There are two spiritual dangers in not owning a farm. One is the danger of supposing that breakfast comes from the grocery, and the other is that heat comes from the furnace." - Aldo Leopold
Edited 2/13/2007 9:35 am ET by JimV
Thanks Jim,I should clarify by "stabilize" I meant to physically add say butterflys or in the case of once edge that the crack is misaligned; a spline or something....I agree is nothing comes at first, file it away but I also feel perhaps I should get more of a sense of it before "out of site".That cup is one thing that bugs me..if it was more flat it would have greater possibilities. As I looked closely last night I noticed that it's almost a full section of the tree with a bit of sap wood on each side although on one just a 1/4" or so.I guess in on sense it has enough issues to not be all that valuable or unique and that can be a blessing or curse: ie either in haste make smaller more solid boards or really give it some time and skill and salvage the entire board as -is.Thanks again,Bro. LukeBro.Luke
I love cocobolo! Particularly if it's from Nicaragua/Honduras as those have the best coloration IMHO. It's currently my favorite wood and I've got a couple small planks sitting around here waiting to be cut into.
If it were me I would cut it down and use for smaller projects or accent pieces rather than try to salvage it as it is. Although I could imagine it salvaged with butterflies and whatnot playing a key role in some sort of Japanese-esque piece.
Hey Luke. It sounds like the cupping is probably what you should normally expect from a wide flat sawn board as it dries. If you look at the end-grain, annual rings, it would normally cup away from the heart, and the smaller the arc of the rings, the more the cup.If you try to flatten it by surfacing it you will end up with a 1/2" or less thickness, so I guess you can rule that out. I would not cut it yet until you get some inspiration. You might want to shave a little off of the hump of the crown, so you can see how deep the dark color goes. I think this wood is great for small works, especially while it is fresh. Some woods just get better with age, however I think this is best when it is just finished before it darkens.
"I guess this is the first piece of wood I'm letting make the decsion. Previously and still I design a piece and search the wood based upon my vision. Not so here."
Hah!
Given a choice I'm betting that stick would have chosen to be left alone to grow it's life away and die peacefully in the forest.
Go ahead, enforce your vision on it- it's already dead.
Lee
Gee, it's getting harder to stir the pot around here.Lee
I agree with most other posters: Leave it alone until you are ready to do something with it.
Better yet, send it to me and I'll hold onto it for you. I have a dwindling chunk of cocobolo who needs a friend.
BroLuke,
I also have a small chunk of cocobolo that has been sitting on a shelf in my shop for several years now...and will probably be sitting there for several more.
I'm thinking that after I learn how to veneer successfully, that I will be able to find a use for it after I turn it into veneer.
Monte
Luke,
I have worked all types of wood without any problems, a few years ago I bought a pretty chunk of cocobolo. I turned some handles on the lathe and the dust was really toxic to me. My skin became highly irritated and I had some serious breathing problems. Your experience may not be similar but I advise you take all precautions.
Dennis
I guess I'll wait a while...I'm more curious as to what degree I should clean it up to see what's really there...to help with the design so I get the best of it.Thanks everyone!Bro. LukeBro.Luke
Turn pens with the wood Cocobolo makes for an awsome pen with a wax finish.
A special piece of wood with live edges demands a special project. As long as you're trying to listen to the wood read Krenov and Nakashima for inspiration. I had a simliar situation with two huge (25"x100"x2") Koa planks I made a my dining room table out of. There was some twist to it that would have cost me way more thickness than I was willing loose in planing so I ripped them in thirds and pretty much cut the lost thickness by 2/3s in the process. The glue lines are hard to see and it pretty much looks like a 1 5/8" thick, 2 board Koa table top with an ebony stringer.
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
