I need a #4 or 41/2 smooth plane. I can’t find one in the local second hand/antique stores. The l-N is $299. The Clifton is $199 and looks like a very heavy (6lbs) casting. Are they better then Stanley/ Record or that much inferior to LN?
Frank
Frank, I'd say my new'ish Clifton No. 4 is a superior tool as compared to my Stanley's by quite a bit. It took about fifteen minutes to check it over for a flat sole, to knock off a sharp edge on the back of the frog where I habitually rest my index fingers- i.e., both index fingers, depending on whether I'm working right or left handed, a slight adjustment to the pin that locates the removable cap iron, a wee sharpen, and away to go. The depth setting has very little whiplash, which is a big improvement on the Stanley's, and I use the hell out of the thing now. It seems to stay sharp'ish and usable for quite extended periods, but I do tend to use two or three smoothing planes, a block plane, and scraper in tandem so that I don't have to make many depth adjustments- I have an old Speirs smoothing plane set coarse, the Clifton set medium to fine, and a Stanley set to very fine, followed by the block plane set at extremely fine. The Clifton is a rather nice tool, but I've never owned or really used a Lie-Neilsen to compare the Clifton with. Maybe the Lie-Neilsen is a step up again, but in truth I have no idea. Slainte, RJ.
*Sgian,Why the Spiers set coarse and the Stanley extra fine? Is this an infill plane? I would think that you would have the best plane set for the last cut. Just wondering as to your techniques.Matt
*Matt, the Speirs is an infill plane, probably from about 1880. It's got a good bi-metal iron-- not original-- that will hold an edge for quite a while, so I set it a bit on the coarse side to tear stuff off in a bit of a hurry to get a generally level surface. it's one of those planes you adjust with a hammer or mallet. A whack at the heel, a whack at the toe, and a whack at the dull end of the iron. It can be a bit hit or miss, if you get my drift----- which the plane certainly does, he, he. The Clifton I tend to set fairly fine, but because it doesn't have much whiplash, I can fiddle a bit to good effect as I'm working. The Stanleys I have tend to suffer from major whiplash and fairly soft irons, so I like to let them work lightly to preserve the sharpness for as long as possible. The block plane, a Stanley, or Record I can't recall which one I've got also suffers from a lot of whiplash, so once it's set I just like to leave it there. Anyway, it usually seems to be that after about 15- 45 minutes of serious hard work all the planes are dull, or dullish, and it's about time to sharpen them all, which is kind of handy, but I do end up with all these lever caps and cap irons all over the place for five or eight minutes, or so, as the stones get their workout. Slainte, RJ.
*Frank, I bought a Clifton #5 a few months ago. I'm very pleased with it. Except for a very slight (almost microscopic) dog-ear on one corner of the iron, and needing final honing it was ready to use from the box. Speaking of boxes, Clifton obviously takes pride in this product: it was in a box, in another box, finally wrapped in some kind of moisture proof paper. Also, as Sgian noted, very little play in the adjustment wheel. I have a few LN models (scrapers, beading tool, and block plane, but no LN bench planes). I don't see how their #4 could be $100 better than the Clifton, unless having bronze is worth that much to you. Danford Jennings did a thorough review on a Clifton he bought last year. A search under his name should turn it up with much more details than I have mentioned. GP
*Friends,Thanks for the info. I will probably get one. ThanksFrank
