Can you offer any advice on clamping mating 22 1/2 degree edges? This is on a 6 foot long face frame which joins a corner cabinet side edge to make a 45 degree face. I plan to biscuit the edges together, but don’t know how to push/pull them tightly together while the glue sets.
Thanks, Bob
Hi Bob.
Apologies for the late reply. I bet I'm too late to help. I'm having a bit of trouble imagining your scenario because of the bit about the angles. If the jist of what you're doing is attaching the faceframe to the cabinet, I have two suggestions you might consider.
The first is blue masking tape. Wrap a piece tightly every few inches for the entire 6-foot length and you should be able to get it pretty gap-free. The biscuits will really help keep the pieces aligned as you work your way down the length.
The other idea is some sort of clamping block of an opposing angle. If you can reach a clamp from end to end, the clamping blocks can help put the pressure against the odd angle.
Sorry again for the delay. I hope that helps.
Matt
