I’ve glued up a lot of panels without using cambered cauls but the table top I am working on is large so I’m going to make up some cambered cauls. I can’t seem to find any information on whether cambered cauls are used on both sides of the top (i.e. opposite each other) or whether a cambered caul is paired with a flat caul (flat caul on the bottom and cambered caul on the top.) Any thoughts?
I use on one side
Since the purpose is to flatten the surface, it seems to me that you want a flat surface underneath. I had a 32 inch diamneter lazy susan that I built for my wife and I used cauls only on one side. The other side was jointed thick boards that supported the cauls.
Don't know if that is 'right' but it worked for me, That table was flat and needed only finish sanding.
Forrest
Mill your lumber flat and square
Use quality I beam clamps. And you will not need cauls
Cambered cauls...
Been using them for 40 years in small custom shops and my home shop. Have always milled the wood to finish thickness and edge glued the boards in one shot without biscuits or dowels single handed. Top and bottom cauls have crowns and are spaced every 18". When the cauls are removed I only have to scape the glue beads and sand the mill marks. With cauls you can use bent twisted pipe clamps and get better results than Jorgensen I-beam bar clamps. Curved cauls are the basics of a veneer press. I typically use 1/8" crown on a four foot caul.
