Can anyone tell me if it is usual to stain the interior of cabinets?
BCPA ,
Whether or not to stain cabinet interiors is entirely up to you and the person you are making them for . Also the type of cabinets may determine your question . Display type cabinets and openings with glass doors and china cabinets and such typically look better if the same in and out . As far as a chest of drawers or other pieces that the insides may not be seen , you can stain them but it is not necessary to do so . Personally I do not stain the insides of kitchen and household cabinetry unless glass or open display is there , nor do I stain the drawer boxes .
dusty
Be careful that whatever you use to finish the interior of a cabinet doesn't have a lingering odor because the smell will last for years and contaminate anything stored in the cabinet. Oil and varnish finishes will have an odor problem. Shellac over a water or alcohol based stain would be the safest route to go.
John W.
Edited 11/23/2005 12:17 pm ET by JohnWW
I use a clear w/b finish. I like the natural wood grain ,even though I make my boxes out of shop birch. No problem with orders. I use a flat or very flat to give it the unfinished natural color.
I usually stain everything but drawer cabinet interiors. I do stain those back about 8" so that you see the stain color when the drawer is open. If the drawers are more like pull-outs, I'll stain the entire interior.
http://www.finishwiz.com
For kitchen/laundry/bath cabinet cases I use pre-finished plywood - problem solved! It's Nova finish - 2 coats UV cure clear epoxy. Great for drawer boxes as well. Doesn't cost a whole lot more than unfinished ply, and when you factor in the labor and finish materials it's cheaper IMHO.
I second the use of pre-finished plywood (maple)when appropriate. I generally don't put any finish on the insides of things I've built unless I think there would be a problem otherwise. If I do it's usually a little bit of shellac then wax.
-Paul
One consideration not already mentioned by others is light & color.
I like to keep interiors light in color, and reflective, if seeing what's stored inside is important. On the other hand, some interiors - like A/V cabinets - are better off dark because they don't call attention to themselves.
-Jazzdogg-
