Willy,
21 X 28 is no big deal, specify 1/16th inch glass and use 3 hinges per door to be safe. I have hung 18″ X 54″ doors with glass (2 panes) using 3 hinges per side with no problems. I use Blum hinges but I’m sure other high quality brands will work just fine.
Lee
For a looooog answer to this question, see the joinery section , post http://forums.taunton.com/n/mb/message.asp?webtag=fw-knots&msg=45809.1
Mike D
As with Lee, I make glass doors larger than this all the time. I use M & T joinery, but I suppose the bridle joint would be equally sufficient. Single pane glass is the way to go. It's thin, and not as heavy.
Edited 3/8/2009 5:17 pm ET by JeffHeath
Thanx Jeff, seems the door size is not a needed concern
thanx again
willy
Thanks Lee, have had great success with blums and adding a third hinge each side will be the ticket-based on other replies the door size wont be a prob.
regards
willy
