I’m just finishing up the installation of some kitchen cabinets for a friend and was wondering if anybody had any recommendations for door catches.
This “friend” designed the cabinet and made some changes along the way so here is what I have to work with.
The face frames are 1″ thick and the doors are 7/8″ thick and inset. The cabinets are painted white and I have already installed the hinges. The hinges are a non-mortise variety (again her design) after quite a while, all the doors are on nicely. A few of them are flush on the edges and have an even space around them but don’t seem to want to close fully without a little preasure.
I’m looking for an idea thats easy and inexpensive and keep in mind the cabinets are already finished and installed. Please keep in mind this cunundrum is not by my design so please no questions on why I didn’t do something this way or that. I would have prefered thing to go quite differently from the begining.
Why not a simple magnetic catch? You can get plastic-bodied ones for less than $2.00, and brass-bodied ones for about $3.00.
Steve,Thanks for the reply. That is what I was thinking as well. Would you mount them to the bottom of the cabinet or is that too obtrusive? I can't really mount them to the face frame because as I said the doors are an 1/8" less thick than the face frames.
For base cabinets, I'd mount them in the upper corner, where they'd be the least visible. If the face frames aren't deep enough, I'd just cut some little spacer blocks, glue and pin them to the backs of the face frames, and then mount the catches to the blocks.
Hi gcg ,
For a more old fashioned and classy look you can use " bullet catches "
There is also the old style friction catches .
The bullet catches are basically easy to install once you mock up and practice a few you will be a pro .
dusty
Thanks dusty,
I was looking at those as well. Are they hard to position and drill for (with a hand drill) to set the door flush? Can you put the catch in the stile or should it go in the rail. I'm assuming the part with the spring loaded bearing goes in the door but then again the frame would make sense too. Does it matter?
Thanks.
g,
I have always put the spring end in the door and the ramp affixed to the opening .
With a few practice trials you will be an expert at placing the ramps , basically center the part drilled into the door , then it's just a matter of marking and hand drilling .
you can do it
dusty
