I need some help finding some chiels to make the set I have complete.I received a sett of BuckBrothers chiels from my grandfather.You see I am missing about four or five chiels from the set. They are pairing chiels ,the era I believe is60,s to late 70,s.I look on the net at Buck Brothers but they where know help. I don,t know if their in bussness any more.
Can you post a picture or maybe a link to ones like yours from an old tool seller's web site or ebay's vintage chisels pages? Buck Bros. made alot of chisels for a very long time.
You might want to check out Craftsman Studios out in California.
http://www.craftsmanstudio.com/html_p/BuckBrosChisels.htm
The story goes that they discovered an original supply of 1960's era Buck Bros. rough forgings, bench, crank-neck and paring chisels and have had them finished off.
I bought a set of the crank-necks and they're nice, but mine had lousy job with the finish grinding. Of the set of five I bought, I spent hours lapping the backs of two of them. (they were .010-inches convex across the back). However, once put right they are very nice and the steel is as good as any. They might be a good match for yours.
No affiliation, etc. etc. just a somewhat satisfied customer.
David C.
Edit: Translated into English
Edited 2/28/2007 10:55 pm ET by DCarr10760
David
I read your post and had to reply. While I have a complete set of LN chisels, both paring and bench, I recently came into a set of brand new old stock Greenlee butt chisels. I just wanted to let you know I share your anguish regarding TRYING to get the backs flat. So far, I've gotten 2 of the 6 flattened and sharpened. I'm presently working on the 2" chisel. What a pain in the a$$!!!!! I've got at least an hour and a half on 80 grit paper, and the two corners are still 1/8" away from being flat with the rest of the back. I paid $40 for the entire set, including very nice leather washered ash handles, but it may be a month before I've gotten them into shape. At the end of each work day, I spend 20 minutes or so sharpening all the tools I've used for the day, and I spend an extra 20 minutes or so on these. I guess I'll be at it for a while.
On another note, thanks for posting the Buck Bros. chisels. The cranked neck chisels are very intrigueing to me, as I don't have any, and have had the occasion when I wished I'd had one. Are you happy with the quality of the steel, or are they like the garbage sold at the Home Depot.
Walnutz
Walnutz,
The steel was okay, as good as any, although being long paring chisels I haven't subjected them to severe use and they've kept an edge. But I don't use a lot of real hard woods, so I can't say for sure.
My problem with them is that they look like they were ground on a flat belt without a backing plate and they pressed hard against the belt, rounding the backs.
You know from our LN chisel discussion that I don't go to great lengths to get the backs of chisels polished, but I do want them flat, particularly crank necks which are used (by me) registered off of the back.
I worked on the 1/2 and the 3/4, the rest I'll wait until I can talk my company into buying a surface grinder!
Best Regards,
David C
Just a thought about your chisel backs on the old greenlies I have a Samuri bench plane blade that I got out of the defect bin at a store. The clerk said it had a low spot in the corner on so when you tried to flatten it you would end up with the whole thing flat except the corner. I took the blade home and gently tapped the bevel side with a ball peen hammer and then re- flattend it and all was well. I might of been lucky but you might try that.Troy
Troy
I've actually seen that movie before, and it didn't turn out very well for me. I cracked the corner off of an old chisel doing that. One has to be very careful doing that with steel hardened to the hardness of a chisel (Rockwell 59-62). I've yet to re-grind that one, as I'll need to remove about 3/8" of the chisel all the way across to get that one in working order again. Thanks for the tip, though. I just don't trust myself after what happened the last time.
I think I'm just lousy with a ball peen hammer. I was trying to tighten up the sideways adjuster on an old bedrock plane about 3 years ago, and cracked a corner off the frog with it. Clumsy oaf!! I'll leave peening metal to the plane makers like Philip.
Walnutz
I think I was very luck and that I did not have to bend (flatten?) the blade that much. Anyway makes one appriciate a flat blade.
good luckTroy
Good news
Please sen me reply for this mail [email protected]
Good news
