Hi,
I’m just about ready to start my next project. Just sitting down figuring out the costs. and writing up the materials list.
I am trying to decide how to cut a 10 ft long board in half for the sides of the bookcase I’m about to build. a regular saw just won’t do. I couldn’t cut a straight line if my life depended on it. The sides of the bookcase are 54 1/4 inches heigh. so I will purchase 1X10X10 board. I know it’s not safe to cross cut a board that long using a table saw. So what should I do? I don’t have a proper miter gauge for cross cutting. I have no outfeed table or sliding cross cut sled. Unfortunately I don’t own a radial arm saw or circular saw. My chop saw only cuts boards 6 inches wide so that’s not much good to me. I suppose I could use a straight edge and jigsaw. But Im willing to bet the 2 pieces won’t end up being the exact length. What tool would you recommmend? A straighedge and a good circular saw would do the trick perhaps..
I won’t have a problem dadoeing for the shelves. It’s just crosscutting the boards thats going to be problematic.
Any suggestions.
Wendy
If push came to shove, I'd cut as close to a line as poss with a jigsaw and straight edge, then clamp both boards together, reset the straight edge and use that to guide a router with a long straight bit to equalise the length of both boards.
Mike Wallace
Stay safe....Have fun
Handsaw. Use a square to make a line across and down one side of the board and cut the line. The secret is to make nice long strokes and sight down the blade as you are cutting. Practice on some scraps and you will be surprised how easy it is.
Scott C. Frankland
Scott's WOODWORKING Website
"He who has the most tools may not win the race of life but he will sure make his wife look like a good catch when she goes to move on."
Get a straight piece of wood. Set it square to the board with a framing square. Use the board as a guide for a skill saw. Cut the piece upside down, as you will get some blowout on the top. So good side down. Tape the cut line with blue masking tape.
This is what I do.
There are also commerical guides, like clamp 'n guide available that do the same trick.
Boris
I have used my mitre saw, which also only cuts 6' or so, on wider boards by making sure the fence is square then clamping a stop block an inch or 2 longer than I want my final piece away from the blade. My stop block is 6-8" long and I try to square it to the blade also. Butt the piece against the block and cut, flip and cut again. Do the same with the second piece. Move the stop block to the exact length you desire and repeat on the other end of each board. I have found as long as I keep the board tight against the fence and stop block, the ends come out square and the 2 pieces are the exact same length. My mitre saw table sits flush with the outfeed tables on both sides so the boards don't fall away and it helps them to butt against the stop block securely.
Try the luber yard where you will buy the wood. Most of them will do this for free or a little extra. Final fall back could be the old fashon hand saw. Go slow and use a framing square to get a good line. You could try a rental store for a circular saw. Good luck.
HI Guys,
Thanks for the tips. I know this is hard to believe but I don't have a hand saw. But I do own a clamp'n guide and a router. One of these days I might splurge on a skill saw. I'll have to use my jigsaw for now and cut as close to the line as possible and then finish up using the router. I guess my flush trimming bit will do Not sure if I have a straight router bit. Think mine is a spiral bit and I'm not sure if it's a down spiraling bit or an up spiraling bit.
Wendy
A spiral bit will work as long as you use a backer board so that the router doesn't blow out the end of the board when you are making your finish cut.Scott C. Frankland
Scott's WOODWORKING Website"He who has the most tools may not win the race of life but he will sure make his wife look like a good catch when she goes to move on."
Cut halfway through on the miter saw, then turn the board over (not end for end, just flip it) and line your cut up carefully, and cut the rest. Works like a charm.
Michael R
