Hi All,
I’ve been building a low-profile (meaning longer than high) cherry bookcase from Woodsmith plans. It called for all of the carcase, as well as the top, to be built from a single sheet of 3/4″ cherry CVP, then edged with cherry hardwood to create the look of an all-hardwood bookcase.
My problem is, I made a mistake (really!) that’s left me without sufficient ply to make the top. Originally, the top would have had a tongue all around to accept the grooved cherry edging. The top is designed to slightly overhang all 4 sides.
I do have a piece of brazilian cherry, which would look just great, that I could substitute for the CVP top. It’s a finished (S4S) piece that’s been laying in my wood storage area (slightly cooler than the shop) for over a year – no discernable warping or cupping.
My question is, of these three alternatives, which is best?
- Use the Brazilian cherry without any edging
- Glue and screw
- Screws only to allow for lateral (front to back) wood movement;
- Use the brazilian cherry with the same tonge-and-groove construction to help deal with wood movement;
- Spring for another sheet of cherry CVP to replace my wasted top.
Naturally, I don’t want to spend extra money if I don’t have to, and I think the brazilian cherry would look beautiful, with or without the cherry edging. But I also don’t want to be penny-wise and pound-foolish.
I’d appreciate any advice you’d care to offer. FYI, the plan comes from Woodsmith issue 155, “Low Cherry Bookcase.”
Thanks in advance,
Mitch
“I’m always humbled by how much I DON’T know…”
Use the cherry (you know you want to). Modify the plans if necessary to be able to attach the top as any solid wood top would be attached....ie. allow for seasonal movement. Use sliding dovetails or simple hold-down cleats.
"Use the cherry (you know you want to)."
You got me pegged...
Thanks.Mitch
"I'm always humbled by how much I DON'T know..."
