Afternoon All
I just got a great deal on 11 4×8 bonded panels, highpressure laminate on 1 side and a glued on paper type material on the back side. I want to make cabinet doors from some of these. Has anyone every tried gluing veneer to the paper side of this type of panel? I was thinking a cherry or maple. The panels all have what the company called Slate Element. Not a bad color but a little dark for floor to ceiling cabinets in the laundry room.
Thanks for your input in advance
Duane
Edited 5/15/2009 7:24 pm ET by DuaneR
The conventional wisdom when veneering is " Treat both sides the same". This is to have a stable panel. So you would need to veneer each side. Might check out Joe WoodWorker.
That might not be a paper layer on the back, but rather "backer laminate." This is material sold by the formica suppliers, intended to be the back side of panels. It is essentially formica without the colored surface. Its purpose is to provide balanced construction to the panels, to prevent warping.
After cutting it up today the backing sure looks like a paper. Well saturated with a glue, it breaks on the overhanging edges like glass, trims well with a razer knife. I have been looking at this while working with it ,it sure looks like it would take a veneer. Might try my hand at some marquetry. I will most likely try it on shop cabinet door first.
Thanks for the good info
Duane
If you can put some heat on it with a heat gun, you can tell if contact cement was used to stick the backer on. If so, I would not veneer over that.Otherwise, before doing a large project, I would glue a sample of your chosen wood, and glue, then do your own QC test. I like to rip the parts into strips that I can break by hand different ways, to see how and where it breaks.Sometimes a twisting break may show where the weak spots are better than bending forces. Even if the backer is glued on good, and your glue line is good, if it splits down the paper, that may not be as good as gluing to wood or other substrates. Try splitting down the backer with a chisel after gluing your veneer on. If it doesn't, you should feel better. I would feel better about my own test, than taking someone's advice who can't even see your material.
Phenolic laminates like Formica are paper. Brown kraft paper, saturated with resin.
Duane,
When all else fails see if you can get in touch with the manufacturer and see what they say.
Greg
