Just trying to save time. I have a cured table that I french polished a week ago and it blushed or clouded slightly in one spot. Any one figured out a quick way to get that out of there?
If it is moisture trapped in the finish then some linseed oil or parrafin oil that is allowed to stay on the spot over night may work. You may have to rub it out with some sort of abrasive like pumice then touch up.
That is unless you did not get all the oil from the surface in the first place. If that is so then try making a small pad charged with just alcohol and rub the spot as if you were polishing it and see if that works.
J.P.
I am just trying to get out of polishing it some more. I heard about a trick with Xylene but I don't know how to do it.
